Below is an overview of the BrainDrive Install System for Windows and Mac, followed by development discussions.
BrainDrive Installer Overview
BrainDrive Installer is a desktop-oriented management utility that provisions and controls the BrainDrive AI platform on Windows. It orchestrates installation, configuration, updates, and lifecycle management for the BrainDrive repository, which delivers a FastAPI backend, a Vite/React frontend, and a plugin ecosystem tailored for AI-centric workflows.
The installer bundles quality-of-life improvements—port management, environment setup, secrets templating, background process supervision, and GUI feedback—to make running BrainDrive approachable for both new and experienced operators.
Key Capabilities
- Guided Installation – Ensures Miniconda is available, clones the BrainDrive repository, prepares virtual environments, installs dependencies, and generates environment files tailored to the user’s configuration.
- Service Control – Launches or stops the FastAPI backend (via Uvicorn) and the Vite development server for the frontend, tracking status through a shared process manager.
- Configuration Management – Automates
.envfile generation and migration using theBrainDriveSettingsManager, preserving existing secrets when regenerating files. - Updates – Provides a one-click update button that safely disables while services run and executes
git pull --rebasewhen the stack is idle to keep the local checkout current. - Logging & Diagnostics – Writes detailed logs under
C:\Users\<user>\BrainDrive\T1\logs, surfacing backend readiness probes, button state transitions, and installer actions for troubleshooting.
Application Components
Graphical UI (Tkinter)
- Presents “cards” for each managed product—
card_braindrive.pycontains the BrainDrive card. - Includes buttons for Install, Start/Stop, Update, and Settings, with dynamic enabled/disabled states.
- Uses
ButtonStateManagerto ensure consistent control over interactive elements.
BrainDriveInstaller Core
- Located in
installer_braindrive.py, inherits fromBaseInstaller. - Manages paths, repository details, conda environments, plugin builds, and service start/stop routines.
- Coordinates with:
GitManagerfor cloning and updates.ProcessManagerfor tracking backend/frontend processes.NodeManagerandPluginBuilderfor frontend/plugin setup.
Settings Management
settings_manager.pyreads/writesbraindrive_settings.json, templates new.envfiles, and respects stored secrets likeSECRET_KEYandENCRYPTION_MASTER_KEY.- Dialog (
settings_dialog.py) allows GUI editing of hostnames, ports, security flags, and performance parameters.
Logging Infrastructure
installer_loggerconfigures file and console logging for each run.- System information, button state changes, cloning progress, backend health probes, and shutdown routines are all captured.
- Logs are timestamped, making it easier to diagnose start-up issues (e.g., port conflicts, environment configuration errors).
Workflow Summary
- Launch Installer – Starts the Tkinter GUI and initializes the shared
BrainDriveInstaller. - Installation Phase
- Confirms disk space.
- Installs Miniconda if necessary.
- Clones BrainDrive, sets up environments, builds frontend and plugins.
- Service Control
Start BrainDrivespawns backend (uvicorn main:app) and frontend (npm run dev) on configured hosts/ports.- Health probes ensure backend availability before the UI reports success.
Stop BrainDrivegracefully terminates processes and verifies ports are released.
- Configuration Updates
- Settings dialog edits persist to JSON and optionally regenerate
.envfiles. - Services must be restarted to apply runtime changes.
- Repository Updates
- When services are idle, clicking Update triggers
git pull --rebaseinside the existing repository. - Button disables automatically if backend/frontend are active to prevent conflicts.
