Starting a thread here for updates/conversations related to the BrainDrive repo.
@djjones, the updated roadmap is ready for your review: BrainDrive PR #346. It only changes ROADMAP.md and adds one image.
It keeps the roadmap big picture: the mission and five areas (Own, Benefit, Connect, Earn, Decentralize), each with progress and what’s still to do. The detailed order of work stays in the sequencing docs.
Changes today, from this week’s calls:
- Own now starts with finishing the foundation: PAA v1.0, then BrainDrive verified against it, with every place BrainDrive departs from PAA documented and tested.
- Own also shows the Your Memory image (the PAA hero) under the key guarantee.
- Benefit: Experts and skills can each be shared, together or on their own. A skill is part of an Expert, and can also be shared by itself.
- Connect: Resume Builder is no longer named as the first app.
- “install BrainDrive” now links to braindrive.ai/install.
GitHub needs your code-owner approval before it can merge. The required checks haven’t run on the branch yet; I’ll look into that once you’ve reviewed.
@djjones, FYI: the sequencing docs now match the roadmap order we agreed on the calls this week. Nothing for you to approve; if you have questions or concerns, let us know.
Where it lives: braindrive/sequences/ in the Library. The public ROADMAP stays big picture; the sequences hold the order of work:
- Now: foundation first. Software Factory current with PAA, PAA v1.0, BrainDrive core verified against PAA, the factory builds BrainDrive, then documentation.
- Next: Experts and skills, after the timeline pause for skills, agents and apps.
- Later: connections, agents, billing, apps, Builder, hosting, then mobile, voice and devices. One file per stage, so notes don’t clutter each other.
The index is the only place the order is written, and it holds the priority rules for every stage.
Changes to note:
- Build first, then sell. Experts, skills and agents are built and shared free; billing comes after agents, and apps are sold once they’re done.
- One Software Factory. Stage docs no longer have separate build-harness and test-harness items: each stage opens with the factory updates it needs and ends with a documentation row. This replaces the July 23 convention, updated in
braindrive/AGENT.md. - The old V.2 sequence and the 10-13 proposals are superseded and kept in place, marked historical, so links still work. Every V.2 row has a home (listed in the index): Models reliability is part of the factory pass over current BrainDrive, App Platform and App Lifecycle go to Apps, Internet Search goes to Connections, Billing is its own stage, BrainDrive Docs counts as part of the factory, the Neon migration is done, and the job-search apps are dropped (their specs stay in Docs).
@djjones, a question for you about the factory’s override rule, which came up while lining up the BrainDrive specs with PAA.
The problem: On the 10-20 call we agreed that the factory loads PAA’s acceptance criteria first, and a BrainDrive criterion with the same ID replaces the PAA one. But BrainDrive’s specs already number their own criteria AC-1.1, AC-5.1 and so on, the same way PAA does. So an unrelated BrainDrive AC-5.1 would silently replace PAA’s AC-5.1.
What I’d like to do: make overriding explicit instead of matching on the number.
- BrainDrive’s own criteria keep their current numbers. Nothing gets renumbered, so the existing test plans and evidence stay valid.
- A BrainDrive criterion that repeats a PAA rule becomes a one-line pointer: “Inherits PAA AC-3.5”.
- A BrainDrive criterion that deliberately differs from PAA says so: “Overrides PAA AC-5.1”, and it also goes in the departures register.
- The factory acts only on those two labels, never on a bare matching number.
This changes one detail of what we agreed on 10-20 (“same ID” becomes “an explicit Overrides label”). Since you’re building that rule, what do you think? Does it work for the factory, or do you see a problem with it?
Yes, I think making the relationship explicit is the right correction. It preserves the existing BrainDrive criterion numbers and evidence while removing the unsafe assumption that matching IDs mean the criteria are related.
I agree with:
Inherits PAA AC-3.5 for an unchanged inherited rule.
Overrides PAA AC-5.1 for an intentional departure, with a corresponding departures-register entry.
No implicit override based only on a matching ID.
I would add one validation rule: a bare BrainDrive criterion that collides with a PAA ID must fail validation or be retained with a source-qualified internal identity such as PAA:AC-5.1 and BrainDrive:AC-5.1. It must never silently replace the PAA criterion or create an ambiguous effective test row.
The Factory should also pin the PAA revision, verify that every referenced PAA criterion exists, preserve source/relation lineage in the effective spec and report, and only reuse a PAA evaluation method when it still proves the inherited criterion. An override should require an updated or newly reviewed evaluation method.
So I support changing “same ID overrides” to explicit inheritance/override declarations.
@djjones Here’s the BrainDrive prep from after today’s call, so we can move fast on it tomorrow.
1. The desktop baseline is release 26.7.23 (ff43e8d, 2026-07-23). That’s what the install page’s “latest” download builds from. main is that release plus two ROADMAP.md commits. So the 594 acceptance criteria, which cite main, describe the code the desktop app runs. The baseline-drift worry from the call is mostly gone.
2. dev turns out to be nearly clean. Since the release it has 16 PRs: your security hardening, the BrainDrive Models credit flow and fixes, docs, and my roadmap edit. The apps and Resume Builder work is all on feature/internet-search-capability (239 commits beyond dev) and my codex/start-business-sidebar draft (118).
So instead of resetting dev to July, we could build from current dev and leave the feature branches behind. That keeps your hardening and credit fixes without redoing them. Can we decide that on tomorrow’s call? It changes the rollback work.
One catch if we do: the Models and Provider settings criteria cite main, which doesn’t have the credit changes. Those two specs need checking against dev during onboarding.
3. Keep/trash list. The full list
- My side, ruled:
- Keep #342 (sidebar marks the open file) and #286 (roadmap).
- Keep #349 (expert sidebar and Business Idea interview, including the conversation star) as a design reference only. It gets rebuilt on clean
devfor the experts release after the plugin decision, not merged. - Trash my 17 Resume Builder and app PRs.
- Your side, proposed for you to rule on:
- Keep your 15 PRs on
dev. - Keep #350’s tool-source fix (I saw you’d already put it on your keep list).
- Keep #339 if the save race exists on the baseline.
- Trash the apps runtime and the Resume Builder work.
- Keep #317, #310, #321 and #290 as references only.
4. Story scope for onboarding evals (D898). The real list was much smaller than the “17 + 16” from the call: Host Chat’s criteria use a different format, and most of the rest were already Deferred.
- No evals: the 12 already Deferred or Removed stories, plus Page Spec PJ-10, 11, 14 and 17, which stay Open.
- PJ-15 (keep my profile current from conversation) becomes Confirmed, since the page stories already promise it. Docs PR 171 needs your review: https://github.com/BrainDriveAI/BrainDrive-Docs/pull/171
- Accounts US-5 (forgotten local password) stays Confirmed, though it isn’t built. Today’s “Forgot password?” screen tells the owner to delete
.braindrive/auth.json, a file nothing reads. Proposal for tomorrow: you fix it together with C5 on the clean dev, removing the false instructions at minimum.
For tomorrow, then: decide build-from-dev vs reset, rule on your half of the list, and take US-5 with C5.
@djjones Here are the keep/trash calls on your PRs from today’s call, for you and your AI to review. We agreed to build from current dev and keep the feature branch, so nothing here deletes anything. It only decides what comes onto the clean dev.
- #350 Advance PAA runtime proof and tool-source refresh (draft against
dev): keep, agreed on the call. Rebase it on currentdevand rerun its runtime CI before it merges. - #339 Fix first-open Advanced document save race (merged to
feature/internet-search-capability): keep only if the bug exists ondev. The race showed up through Resume Builder’s package seeding. If that seeding path only exists with the app platform, the bug leaves with the apps and the fix isn’t needed. - #317 macOS Internet Search sidecar packaging (merged to the feature branch): trash for now. It ships through the app-platform package store. Rebuild it when Internet Search is picked up again; its accepted spec stays.
- #310 and #321, the audit events and prompt-audit emitter gaps from the Resume Builder freezes: trash, keep as reference. They’re specific to app chat, but the content-free audit-event design is useful when the PAA audit record (C7) comes up in onboarding.
- #290 First-party app platform and builder workflows (draft): trash, keep as reference. The app platform comes back at the Apps stage.
Your 15 PRs already on dev (security hardening, the BrainDrive Models credit flow and fixes) stay. If you see something on the branch that dev needs, settings and API-key cleanup for example, bring it over.
Full list: 2026-10-26 dev keep/trash list
@djjones, can you confirm the keep/trash calls in post 8 are settled? On today’s call you said BrainDrive is down to a single dev branch, so it looks like they were.
GitHub still shows two of those PRs open against dev:
- #350, PAA runtime proof (keep): is it merged into the clean
dev, or still to come? - #290, app platform (trash, keep as reference): can it be closed?
Also, was #339 (the document save race fix) needed on dev?
A one-line “settled” is enough if nothing changed from post 8.
