BrainDrive Interface Updates
@DJJones here are the items discussed in today’s call from my run-through this morning.
For You:
  1. Change the openrouter default to nemotron
  2. In the sidebar there should not be two your agent pages, only your agent at the top.
  3. Get rid of the upload button in the sidebar unless there is a reason to have it
  4. Get rid of the file number beside the advanced
For Me:
  • Ultra Model showing links to files that are not clickable instead of pointing people to the sidebar.
  • Ultra model not asking one question at a time.
Any questions or issues let me know.
I did a quick test, found 2 things.
  • The arrow I circled will minimize the sidebar, it does not have upload functionality any longer.
  • I can see the double Your Agent, based on what it took to discover I am going with a your memory issue. I will clean that up and merge quickly..
If you can confirm the arrow please, just to be sure and provide direction as far as remove the current functionality or leave it standing.
@DJJones The + sign I am referring to is on the page surface. So if you click into finance for example you should see a plus sign which you can click to upload files. That’s what I am referring to that we should remove if it is still there.
duh
I will resolve that quickly, the double Your Agent fix just got merged into dev.
Sorry about that, I didn’t understand..
Both issues are now resolved and in the dev branch
great thanks and no worries.
Issues resolved:
  • Openrouter default model changed
  • Production BrainDrive Model is now live with the new model selection
  • BrainDrive no longer needs a model change for BrainDrive Provider, it gets the default model from BrainDrive Models now.
  • File number beside the advanced removed
