Today Dave J and I had a deep dive discussion around all the different options for hosting your AI system. You can find the video recording of our discussion as well as an AI powered overview below.
Questions, comments, and ideas welcome as always, just hit the reply button:
Forum Recap: What It Really Takes to Host Your Own AI System
When people think about hosting their own AI, most jump straight to one question:
“Which model should I run?”
But as we explore in this video, model hosting is only one part of the equation.
There are actually three major components to consider when setting up your own AI system:
1. The Application Layer
This includes your AI interface, databases, and tools like BrainDrive Studio or custom plugins. It’s basically like running a website.
- Cost: Starts as low as $5/month for lightweight usage
- Hosting: Can be cloud-based, self-hosted, or split across environments
- Scale Factors: Depends on number of users, plugin complexity, and active development needs
You can host each piece (e.g. interface, studio, memory) separately depending on your needs and budget.
2. The AI Models (Inference Layer)
Here’s where things get resource-intensive.
- Models need to be stored (SSD/NVMe)
- Then loaded into RAM/VRAM for inference
- If you want models ready 24/7, that server has to stay powered on with the model loaded—driving up costs
There’s a huge cost cliff between:
- Running small models on your own machine or a VPS for <$10/month
- Hosting powerful models with fast response times, which can jump to $100–$300/month or more
3. The Cost & Control Tradeoffs
There are three main hosting strategies:
- Fully Self-Hosted (Local or On-Prem): Full ownership and privacy, low ongoing cost, but limited performance unless you’ve got high-end hardware.
- Cloud VPS / Dedicated Servers: Flexible, customizable, but you’re billed continuously—even when idle.
- Inference APIs (OpenRouter, Groq, Together AI): Pay-as-you-go pricing, great for hybrid setups, but comes with some trade-offs in privacy and control.
Important takeaway: You can mix and match. Run lightweight tools locally. Use cloud APIs for heavy lifting. Host pieces of your system wherever it makes sense.
Why BrainDrive Makes It Easier
BrainDrive gives you the power to:
- Host any piece anywhere—interface, tools, models
- Integrate inference APIs or use your own models
- Scale flexibly with a plugin-friendly architecture
- Keep control over your system, even as you grow
Whether you’re just chatting with your AI assistant or launching a complex AI-powered product, BrainDrive adapts to your needs—without locking you in.
Bonus: Model Match + BrainDrive Studio
In the near future, you’ll be able to:
- Use Model Match to find the best models for your use case (by price, speed, privacy, etc.)
- Use BrainDrive Studio to create dedicated pages for each workflow, pre-connected to the ideal model—local, hosted, or API-based
Got questions? Want to share how you’re hosting your own BrainDrive setup?
Drop a comment below—let’s build together.
